First solar project. Budget sensitive.
I will build a 4x9 36 battery 48V system out of 86Ah 12V AGM UPS batteries. Great shape but used. Won't last forever. Not deep cycle but should be ok for a starter battery setup. Price was right.
Does a BMS make sense at all? Can I skip it for this first install since the budget is low, anyway? Shoestring budget..
The system has 4/0 copper with corresponding copper lugs for interconnects in series. I'll use copper bus bar for parallel sides.
Looking to possibly add an Outback VFX3648, 310W panels sourced locally thru Victron charge controllers, when budget frees up.
But for now, focus is on the batteries and adding VFX3648 or similar to maintain batteries and start using.
All batteries measure about the same.
Safety first:
* What fuses/breakers are needed for the 4x9 48V battery array?
* Will the Outback battery input need external overcurrent protection?
* Any other safety considerations?
* Any other considerations for a smooth startup? E.g. how not to blow the Outback capacitors, how to initially connect and charge the batteries for ideal conditions, etc
* I may add an isolation xformer to clean up inductive loads. Will this help prevent the Outback from tripping? e.g. washer, fridge kick-on, power tools, etc
I am slow and methodical. These batteries are capable of serious discharge (UPS batteries - 37kWh!!) so I will consider all free advice as preliminary before getting a PE involved to confirm the design.
I am a beginner with solar and large battery arrays but have a good amount of related experience and knowledge.. just not enough to stamp an electrical construction document.
Thanks,
Aloha
Safety first:
Thanks,
Aloha
