Hey all,
I'm about to acquire (4) 100AH CALB LifePo4 cells. Looking at a 12v system running a 1000W (2000W Surge) inverter (haven't purchased yet). I was hoping to keep this setup mobile so I can transport it back and forth from home to our cabin. However, I didn't realize the complication of a BMS until I just started researching which one to get...
Option 1: KISS and get a Daly and run everything through the BMS
Option 2: Electrodacus SBMS0
With the Electrodacus, am I understanding correctly that the DSSR20 IS the Solar Charge Controller and I would then not need a MPPT Charge Controller? And if so, does that mean I can't use my existing 24v panel with it? In addition, how would an AC charger come into play?
Regarding the Inverter, I'm looking at the AIG Inverter that looks like it has a Remote Switch option. Does that mean I can utilize that with the Electrodacus? Do I even need to control the Inverter? Won't the Inverter's low voltage cutoff be good enough?
Thanks for any help!
Jeff
Jeff
