I am pretty new at this, and plan to switch from two 6v golf batteries to a diy lifepo4 setup. Will the BMS allow me to set the charge cutoff and discharge cutoff to I run my battery from say 10 percent SOC to 85 percent SOC? The BMS I am looking at is the 120a from overkill solar. If that won't work, is there one that will? Or, do I need a charger that can be set for this? I have a progressive dynamics 4060k charger in the trailer and an epever mppt for the solar panels.
Thanks in advance.
Thanks in advance.
