Did a quick search and did not find much, so here is the application.
I want to make a battery pack that would plug into the boat outboard(electric) or the RV when off grid
Electric outboard on a pontoon boat, 20HP eq rating 8400 watt input, 48V max current 175A Boat is on a small lake, low speed and probably no more than an hour or two at 50%. No charging needed in this mode, just wheel it home and plug into the RV. Not leaving a battery pack in the boat as there is no security at the marina.
RV is a trailer, probably 4000 watt max need. Trailer would have the inverter/charger as this application will be home base for the pack.
Comments, suggestions? I hate the idea of buying a gas motor for the boat and genny for the camper, thought this concept would do both well enough.
TIA
TIA
