My plan is to add 3 more panels to my current system.... right now I have 6 x 245 watt in a 3s2p configuration. My plan is to add 3 more 250 watt panels that have almost exactly the same specs. It is the top end I am concerned about.... possible max output. If I understand mixing panels correctly, I will see the output of the lower wattage/amperage panels.... I read the lower panels will bring down the output of the others. For reference, the current 6 are combined on the roof and brought down to a breaker, the additional 3s will be brought to a second breaker in the same box, so there combined with the other array. So 3s3p.
I'm using a Schneider 60/150 SCC 48v system
The SCC manual has these statements: "Although the solar charge controller can harvest a maximum of 3500W, the PV array size can be as high as 6720 W (based on 48A× 140 Voc = 6720 W)." And: "Do not allow the PV array voltage to exceed 150 Voc (open circuit voltage) under any conditions. The array Isc (short circuit current) must not exceed the 60 A input current rating of the solar charge controller at any time."
Specs....
245: VOC = 37.5 VMP = 30.2 ISC = 8.68 IMP = 8.13
250: VOC = 37.6 VMP = 30.3 ISC = 8.85 IMP = 8.27
Using a great simple formula "onemorebattery" gave me on another question, here is what I get FOR THE MAX. Normal output is easily within spec...
250 watt panels: 3 * 37.6 * 3 * 8.85 =2,995 watts - 2,995/48 = 62 amps
If I am correct about mixing panels... I could expect max output equal to the 245 watt panels.
245 watt panels: 3 * 37.5 * 3 * 8.68 = 2,930 - 2,930/48 = 61 amps
I can't find a Schneider string calculator (apparently you can no longer download it from their site) so I used the one online by Midnite Solar and according to that calculator I am actually way lower. Their numbers hardly resemble my other calculations at all! Here is what I get using the specs off the 250 watt panels:
Rated power: 2250
Anticipated power @ 93F = 2160
Current: 24.81A
Battery charging current @ 57.6 = 39.1A
VMP = 90.9V
VOC = 112.8V
VMP @ -33F = 115.8V
VOC @ -33F = 135.6V
Any thoughts by those smarter than me when it comes to solar math ( not hard to do!) ??
If my first numbers are correct... would you hook them up anyway?
Thank you!
Specs....
Rated power: 2250
Current: 24.81A
VMP = 90.9V
VOC = 112.8V
VMP @ -33F = 115.8V
VOC @ -33F = 135.6V
Thank you!
