justinm001
- Dec 18, 2022
- 1,650
I have 2 completely isolated systems one 12V and other 48V, have the 48V system connected to the 12V inverter to charge but the entire communications systems are separated. Ones completely in a rear bay and other is in the front bumper.
Lastnight at 10:04pm got an error saying no data from the Cerbo to VRM. (was just the 48V so not sure if both). This morning I checked and my TVs showed no internet so I rebooted my 12V systems and they came back on and both reporting data. My 48V cerbo touch was all white and when I went in form the site to remote console it was white. The 12V was black so I unplugged the Cerbo but started getting the flashing amber light for wifi only. Which appears the device cannot boot.
48V was working for a few hours but I was getting an error from the solar saying no BMS so it was off. Both battery banks are 40-75% charged and the coach is at my office with only 15a plug so was relying on solar. Finally just got around to unplugging the 48V to reboot and now its also flashing amber light only.
Both systems have Venus OS large and guimods plus nodered enabled but nothing setup yet. Other than that all normal with nothing on any of the inputs other than victron gear. BTW the 12V is a Cerbo-S GX and the 48V is a normal Cerbo GX.
I'm about to follow the instructions below to factory reset them. But I'm at a complete loss to what could have happened. They're isolated systems and only thing connecting the 2 is my 120V breaker panel. The 48V is even on wifi where the 12V is on ethernet.
Last night I did change the 12V from on to inverter only as it uses 12a min to charge and i was plugged into 15a on the 48v so wanted to drain that battery and charge the 48v overnight so it can charge the 12V in the morning. I had 75% battery so should have lasted over 24 hours with idle load.
Any thoughts on what I should try before wiping everything and starting over?
www.victronenergy.com
