Mr. Live Wire
Any Idea why a breaker in a residential 120/240v panel would have charring on the bus bar and breaker contacts ?
It's a 2pole 50 amp breaker that is fed from inverter
All other breakers in sub are fine and are older than the now damaged breaker that was installed with the solar system. It is an old zinsco panel but all other components look in tact. Just wondering if it's a coincidence the breaker burnt up or could something in the system be causing a breakdown.
