Breaker size
Revid
Canada
Got my system almost done except for a breaker between my solar panels and mppt. Iam attaching a pic of my wiring and a pic from bk of panels . Could someone tell / show me the total numbers( amps and volts) and a suitable size of breaker? I don’t know which numbers to use from bk of panels. Most videos use different abbreviations and it’s totally confusing. Thanks
Usually people install fuses on the solar strings instead of breakers. The midget size (10x38mm) 20A / 690V or 1000V fuse is a common choice.
Iam using 10 awg wire from panels to mmpt so do I size breaker to wire? 10 awg is good for 30 amps so all I can find is 24 and 40 so guessing I would go with 25??
You have 1 string of panels in series , your Isc ls 13.93A , your maximum series fuse rating is 25A , you have a disconnect switch from your panels to your scc so you have the disconnect covered. A breaker (or fuse) would serve no purpose. You would not need a breaker (or fuses) .
There are a number of sites and videos out there that can explain when and how to fuse/breaker solar panel arrays better than I can here.
Thanks Robert, my mistake. The switch you see from panels to scc is what Iam trying to replace, actually it’s not even installed it. I was going to use it but the bolts are to big (3/8”)and I only have #10 wire coming from panels so I can’t find a lug to fit wire and bolt at same time. So I thought I would fit a breaker there instead
Got it I saw the switch and misunderstood . I am using an IMO si32 PEL64R 4 Enclosed DC Disconnect Switch for 2 sets of 5s2p hyundai 300 watt panels (196.15 voc , 19.54 Isc total each set ) the IMO switch has Max. rated current of 32A@600VDC and is rated to be switched under load. it has 4 contacts so I can break + and - of both inputs. if you are staying with 1 string they make a 2 contact switch. IMO si32 PEL64R 2. they also make a 25A and 16A version just replace the 32 in the models I listed.
Yes will be staying with one string so by the sounds of it a 25 A breaker would be good. So my setup would be 4s1p? With the tag from panels above what would my total volts/ amps be? Iam still learning!
VOLTS . Multiply your voc x 4 for 4 panels in series and add 20% to be on the safe side as the voc goes up when the temprature goes down.
AMPS . Amps stay the same , Isc (13.93) 1 string in parallel = 1 x amps 2 strings 2 x amps , etc.
Not sure how bifacial panels effect the numbers as I am not familiar with them.
Reactions: Bop
