D
Deleted member 165
Guest
The first paragraph says if you have many grounding electrodes at the same building or structure they must be bonded.
The second paragraph says you don't actually need the second grounding electrode if your off-grid system is in your house. Adding the second electrode and not tying it to your house system is actually a code violation in of itself and is more illegal than tying to your existing house ground.
IF you are in a seperate building or structure, then they need not be bonded unless you have power being fed from another building or structure.
Thanks! I get it now. I'll take the 1,000' roll of ground wire out of my Amazon cart ;-)
