hogback
I'm not quite sure how I managed this, but my insight facility will not allow me to change and settings on one of my xwpros. I had managed to update the firmware, and had been messing around trying to get a bms recognized. I can power on the unit in standby, but the fan kicks on every minute or so for a few seconds, and the display on the front of the inverter goes out for a second. All fields are greyed out in insight local - can't change anything. I can't even reset to factory defaults. If I start inverting, all seems fine at first and then the inverter makes the most awful screech and goes to fault 56. I looked at some logs, but not sure what it means. The 'in progress' fields soon change to 'failed,' and the 'failed' ones try again. There are no loads or charging connected to this inverter. I can see how some of my messing around might have caused some functionality of the inverter to cease, but I wouldn't have expected a bricked insight local interface. This interface works fine for viewing status, and I can change settings when I move the batteries and insight facility over to another xwpro. Any thoughts? Maybe if I temporarily move my SCP over from my currently running XW+ setup in order to reset factory settings?
