Rednecktek
Solar Wizard
So because I'm paranoid, and I have a well known soft spot for the parking diesel heaters... I've always wanted to make a self-sufficient-as-possible emergency diesel heater-in-a-box.
One common problem I see in the designs of other heater-in-a-pelican-case setups is that you still need to figure out how to power the 12v supply (hook up a battery) and then how to keep that 12v supply running (car charger?) and that's more stuff you have to lug around to make the ting work.
Now, there's no way to get around the fact that solar panels are a bit of a hassle to deploy, but if everything else is on wheels... well... that's a BIG improvement.
So, here's what I threw together
Harbor Freight rolling toolbox
Vevor 8Kw diesel heater
EPEver 20a MPPT controller letting me use 300w of panel (2x150w max label in the instruction manual and side of the box)
100Ah of LFP cells
A rebranded JBD BMS
2x 35w heating pads (I built my battery long & skinny so there's a pad sandwiched between each pair of cells)
Simple digital thermostat (set to come on at 2c, off at 10c)
Wires, fuses, adapters, breaker, extension cords, dryer duct, etc...
It heats up the place right quick!
Now, it didn't go perfectly. I had some fitment issues where I missed a hole and had to re-drill it a little bit over. I also made 1 other major mistake that I'm kicking myself for and I'll let you guys figure out what it is.
We did a 2 hour test run today and it was great other than the dryer hose I used was insulated and got warm enough to slowly fill the place with that hot plastic smell. I'll be replacing that with an all metal one soon.
It's not perfect, but for a first try I'm gonna be proud of myself.
100Ah of LFP cells
A rebranded JBD BMS
