grey nomad
Aussie traveller
Hi to all the DIY solar enthusiasts
I was originally planning on building 12v 200ah bank using 2 12v 100ah batteries in parallel.
They would be used in my caravan to travel off the grid around Australia.
After reading through this very informative forum, i noticed the great deals with Xuba seller on Alibaba for 280ah cells.
The extra capacity would be useful but was thinking i would like to have 2 batteries, one for redundancy.
I would have trouble fitting 2* 12v 280ah batteries in the van and the cost would be out of my budget.
The redundancy would be good for my essential load of 2 small 12v fridges drawing 15A total
No inverter so nominal load would be around 20A and max load around 50A for the air compressor used with my airbag suspension.
Pro's i see with a single 280ah battery are.
Cheaper cost per AH
1 BMS
Less wiring.
No problem with internal resistance miss matching developing with parallel connected batteries.
Con's
No redundancy.
My setup is
450w solar
30A Redarc mppt solar controller,
30A dc to dc buck boost charger from car.
Just looking for any suggesting of what other people have used or setup.
How common are failures with Lithium.
My only experience is with lead acid batteries and have had no problems except the 50% DOD usable capacity of AGM batteries.
Cheaper cost per AH
1 BMS
Less wiring.
Con's
No redundancy.
My setup is
450w solar
