jasonhc73
Cat herder, and dog toy tosser.
i am trying to understand this process. i think when you say no cut means you are just diverting the connection via a different connector to the factory connector on the front plate?
i ordered
43025-1000 (https://www.molex.com/molex/products/datasheet.jsp?part=active/0430251000_CRIMP_HOUSINGS.xml)
43030-0001 (https://www.molex.com/molex/products/datasheet.jsp?part=active/0430300001_CRIMP_TERMINALS.xml)
43020-1001 (https://www.molex.com/molex/products/datasheet.jsp?part=active/0430201001_CRIMP_HOUSINGS.xml) thinking i will solder the battery terminal output and get it outside and use the other connector end to mate with 16S active balancer. obviously this seems to be the wrong connector or i missed ordering the terminal for this.
NOOOOOO!!!!
For the internal connector:
Not Molex parts, Tyco parts, or just 8 breadboard jumpers "might" work. I have some ordered, but somewhere in the mail.
- 1318772-2 12POS 2.2MM Tyco Electronics Header
- This is the OEM connector on the BYD BMS
- I think I can do the same thing in the V2.0 parts list without this, using breadboard jumper wires.
- 1318745-2 32POS 2.2MM Tyco Electronics Header
- USB 1.1 9pin header connecting the 12POS to the 32POS
- If breadboard jumper wires work, this won't be necessary either. (I'll know as soon as the jumper wires get here)
- Ebay Male to Male Dupont Wires(click here for what I ordered)
- For use of connecting the OEM connector directly to each other.
- Ebay Female to Female Dupont Wires (click here for what I ordered)
- I kind of like the idea of using the 12pin to 32pin header connector, that way it's one connector to pull, not 8.
