Would like to know this too.I got mine from Battery Clearing House. Is that where yours came from?
What were the initial voltages like on the packs for yours?
What did you use for initial balance charge?
Darkstar, how did your test initially?
Who did you buy yours from?I have 58 full days of use, 47 on a balancing BMS.
I have been using these batteries and cycling them every day twice a day. Charge and discharge - 5 days a week.
I bought a bunch of "4.0 - 4.5 kWh batteries", yes eight of them.
I would have never known I had less than what I was sold, had This "fiasco" and others not do full-on capacity tests.
I received batteries at 23.3V and 23.6V and was none the wiser.
I initially tried to charge them to voltage they were sold as to charge to (58.4/29.2), and every time after I charged them to that, they all self discharged to ~26.55V. After 3 or 4 days I gave up on that nonsense, and just settled on 54.4, which didn't even work. I just gave up and let 53.1(26.55V) be the number.
You cannot "balance" a broken cell, you can only work around it. There is no fix for a LiFePO4 degraded cell, it is forever a one-way chemical ion reaction that can never be undone.
Out of the 64 cells I have, I know at least 3 are total junkers, maybe 4. Because of these 3 junk cells, the 32 -36 kWh I bought only works out to be 14 kWh of usable batteries. I have sent the people I bought the batteries 3 separate emails since doing a deep cycle test, and still not one reply.
Steve, I am not blaming the solar field here but I feel these were poorly to down right falsely represented. On all my batteries, the data label was purposely removed. I already knew based on dimensions each cell should have at least 200Ah. The actual new spec was 220ah for a total new capacity of 5.63kwh, and I would wager that every one out performed their ratings as most do when new. I would guess closer to 6kwh.
When they were first marketed months ago, they were being represented (likely a guess and not tested) as having 80% capacity left so around 4.5kwh BUT "they need to be cycled a few times and capacity would probably come up to 5kwh"...... Now vendors are just jumping on their sites to change the capacity (after many purchases) to what the REAL numbers are coming in at. Those test results are being debunked with "you didn't balance right, you didn't discharge enough, etc".
They had been represented at a guaranteed capacity of 4kwh, now its "80% of the 4kwh capacity", in which that is NOT even the capacity of the battery! They are about 50% of rated which paints a different picture of the life in these batteries.
At this point I have balanced one of them, charged at .5C, checked balance at full charge of 3.65V, and discharged to 2.6V at .2C 3 times in a row, I obtained 2.8kwh. Even with today's "advertised guarantee" they are not hitting the mark. Sure, I could go to a deeper discharge BUT what is that min value?
In my opinion, if someone is going to sell thousands of used batteries, they should have setup a test bench and ran many spot checks before putting any "advertised capacity" on them! I realize it is not realistic to test every one, but I have not heard of one test so far that approaches the previous advertised values.
I had an opportunity to buy brand new modules out of China with a warranty for the same price/kwh as I have in these well used ones. yes, I am frustrated at this point!
It is said many times that chinese products are junk, but in this case we bought from our own and was and is still being screwed. Some sellers do not even bother to respond. Have the money already so it seems a case of "screw you, bye bye money"i will buy new from now on.if and when there is product to buy.
Drop shipped from BigBattery through Battery Hookup.Who did you buy yours from?
I noticed your subtext under your avatar...Drop shipped from BigBattery through Battery Hookup.
Cat herder... you must be SKILLED!
Now I’m scared to buy two of these from bigbattery.com they are advertising 3kw @$699 each with $350 shipping: https://bigbattery.com/product/24v-lifepo4-power-wall/
