stuffnjunk
I've researched my areas calculated wind load, however, the formulas I am seeing go for a flat surface. If the panels are angled on a ground array, does that change the equation? I also understand that gaps between panels could lower the force applied vs. it being a one solid surface so to speak. I'm not worried about a wooden array, as it would be 4x6 sunk into the ground at least 36" and concreted. I'm thinking about putting it higher off the ground, mainly to make mowing the field easier. I guess I don't have to worry about calculating a snow load, as every video I have seen show the snow melting off bifacials quickly.
