Variation in what quantity are you asking about?I would be curious to how much variation is tolerable. And at what point should adjustments be made or verifying connections.
Are you referring to one of the calculated Examples? If so, cite which one. In post #3 I gave 3 examples of the calculated out of balance for 3 different values of battery IR. Could you be more specific please. I could do a special calculation if you can give the battery IR and link resistance.I see the numbers of the out of balance configurations to be maybe 3+ amps out of 30 or roughly 10%.
GRATS on making it this far before my pedanticism. Start a "Math for Smarties" thread?I said in the beginning I didn't want this thread to be a propellor head thread. The community is not all EE's and I don't want to scare anyone away from reading this thread all the way through.
What would be the typical IR for the batteries, and the resistance of the busbars between two adjacent batteries?How about for the semi-common 6 packs of Gyll batteries in parallel config?
A good bus bar to terminal surface clamping interface resistance is 0.04 to 0.08 milliohm. Poor terminal connection can be much greater. Making low resistance cell terminal connections is one of the common issues with DIY'er construction. Aluminum cell terminals quickly grow aluminum oxide surface coating which is non-conductive.What would be the typical IR for the batteries, and the resistance of the busbars between two adjacent batteries?
That's better than 4/0 gauge cable! A 72mm link of that would have a resistance of .001 milliohm; that's 1 microohm! In such a case I suspect that the clamping resistance will dominate the overall link resistance.The cross sectional area of the bus bars on the Gyll battery rack is ~125mm2.
Have you measured the currents of the individual batteries under load? It's possible to work the problem backwards and calculate what the battery parameters such as IR must be to give the measured currents.The cross sectional area of the bus bars on the Gyll battery rack is ~125mm2.
Have a look at post #25 (also see post #4). The right hand part of the image shows 4 batteries connected to a common busbar with equal length cables. Whether or not it gives a balanced charge/discharge depends on how the load is connected to the busbars. If the load is connected as shown by the red/black load cables, the balance will not be perfect, although it can be quite good if the busbars are thick, low resistance items. If the load is connected as shown by the yellow/blue load cables, the balance can be perfect provided that the IR of the batteries are identical.Can your mathematical model confirm that wiring each battery to a common bus bar, using equal length cables to each battery, provides a balanced charge/discharge?
I haven't found a perfect balance connection for 5 or more batteries in parallel, but the method does give improvements for those cases. I'll post some of my findings about those higher number strings before too long.How could you do it with busbars, using5 batteries in a server rack, for example the SOK server rack with an extra battery set right on top of the top battery (with spacer to make it evenly spaced in relation to the other batteries)?
I think the busbar with slightly inset connection point no longer works in that scenario...Also the "halfway" using cabling. Does this example/method cap out at 4 batteries?
Have a look at post #26 (also see post #4). The right hand part of the image shows 4 batteries connected to a common busbar with equal length cables. Whether or not it gives a balanced charge/discharge depends on how the load is connected to the busbars. If the load is connected as shown by the red/black load cables, the balance will not be perfect, although it can be quite good if the busbars are thick, low resistance items. If the load is connected as shown by the yellow/blue load cables, the balance can be perfect provided that the IR of the batteries are identical.
It's also possible to get a perfect balance with 3 batteries in parallel if the proper load connection to the busbars is made.
I haven't been able to find a load connection to the busbars giving perfect balance with 5 or more batteries in parallel, but I'm still searching for one.
Your diagram shows only one wire connecting to the red busbar where I've shown a blue dot. Surely you have 4 wires connected to 4 studs on the busbar I've shown as 4 big black dots; is that correct? Could you also show where your load cable is connected to the red busbar?I've been following the thread since the beginning. The configuration I'm asking about is a little different. Is it effectively different? I don't know.
What I'm talking about is a small bus bar with all cables connected to it. The studs on the bus bar are no more than 1.5" apart. Despite my lousy diagram below, the cables are all equal length. Maybe I'm asking a question for which the answer is simply obvious, that the balance is as good as you can get.
Could you indicate on my drawing where the load is connected? Is it connected in the middle or at one of the ends of the busbar?It was a quick-n-dirty PowerPoint drawing. In my description I noted that the connections were 1.5" apart, which is pretty close to what you added.
I've done some calculations on a 5 battery parallel string and here are my results.Excellent work and very interesting!
Looking forward for your additional findings using different battery configurations.
