joegambler0
- Jan 5, 2020
- 23
Hi,
I did a full solar install in my last RV. When I do a camper van conversion I want to do it differently.
I want to either use a all in one inverter/charger or a solar generator. With a solar generator I'm guessing I could wire an internal camper plug and connect to rv solar generator plug. But what about 12v fridge and a/c? Do I need to wire in also a step down transformer and will that be inefficent?
As far as the all on one invertor. Doesn't seem like they make good brand ones that are 3K watts and 12v. They seem be either Chinese garbage in the lower power or 5-6K watts and 24 or 48v made more for a house. I do have 48v battery that maybe i can use, but its pretty big and heavy. Would the higher watt all in one invertors be inefficient and also do I need 2 step down transformers for 110 and 12v? Or do you have a good brand to recommend for the all in one 3K watts 12v?
Which setup is best?
Thanks.
Thanks.
