Here in the US we don't have many personal trucks with extra axles(I've never seen one). We also have a lot of truck camper options to fit most trucks and a good supply of heavy duty trucks. For example, I have a RAM 3500 dually which handles a Lance truck camper very well. We've gone up mountain roads and over some very poorly maintained dirt roads with no issues. I knew there were some truck campers in Australia but I didn't realize how limited the supply there is until I looked it up just now.Freep. Not where I am looking at. Just a note. My brother had a Landcruiser tray with an extra live axle. He could go anywhere with it. The lazy axle gets limiting.
Unless you can find a cheaper source on the MPPTs and get 2 of them that are synchronized?Thus a 3 plus 2 will be inefficient and the similar as a 2 plus 2.
Super interested in this thread as I am looking to do the same. I can't decide how to charge my battery. My current thoughts are that 7kWh is a lot of power. Adding an air conditioner would need a whole lot more if I want to end the day with (near) fully charged batteries. As for the air conditioner, you also have to be aware of the condense water and noise. I am personally leaning towards a mini split system. I have done camper van in the late 70's and all I needed was a small light bulb. In hot day's I would park in the shade and travel with the weather. Now I a married, I need to have luxury or risk a divorce. However, I really enjoy learning new things and love to see what you finally end up doing and your findings.I spent the day firstly doing some sort of electrical audit. Then I revisited the A/C notes I had and fell down the rabbit hole. Several points come up. I would only need a 5,000 BTU aircond. With good insulation this will be ample. Water is the enemy. A slightly undersize A/C will dehumidify the air and make the van cooler. An oversize A/C will make the van clammier. The compressor will cycle on and off thus using less power. However I am going down the right track. 1500w of solar seems to be the mark. The 280 AH LiFePO4 24v will do the job sufficiently. The 370w panels make good sense. So it comes to the format that I install them. 4 panels would just be there. The original 5 is better and a better install.
We come back to the 3 primary panels and the 2 slide outs.
Owenfi can you please explain the synchronization? Is this two identical MPPTs with the same settings? At this stage this seems the better course.
Not sure if that will work in parallel though. The one amazon question pertaining to it says it's okay if the size is the same, but in our case it's not.For 2x the XT in series the Tracer 4215BN will do.does 40A and 150V max input and is affordable: <200 USD
The redtape is something I have to checkout. I do believe that once you hardwire the 240v in, you start with a lot of compliance issues. Now that I know what I need to do, I can start going down that path.
The inverter is somewhere that I can save some cash. There are many that you hook up to the battery and simply plug your appliance in. I just have to find a well priced unit that will work reliably. Victron are way more expensive.
Ohhhh yeah, I remember my Australian roommates telling me they had to have an electrician out to change a bulb. They might've been kidding.The 240V work has to be done by a "licensed" electrician.
This one looks pretty nice to me. Worth the extra for pure sine and optional AC-in.This was the first one I looked at. The brand is Lyvuan. Says it is pure sine wave.
