Can a string inverter be mounted under the panels (groundmount) and the AC feed ran to the house (approx 70 ft/ 21m)? And just FYI, I don't plan on using micro inverters.
Right now my initial plan is to use 48, 395 W panels with 2 Solis 10K inverters. Mount the inverters under the ground mount and run the AC lines to the meter connect (through a disconnect box). If anyone has an inverter mounted under a ground mount system can you please share pics. Thanks.
