Peter Laub
Is it correct that 5 wires are clamped together between the balancers?
NO! There are not clamped tother 5 wires!!!Is it correct that 5 wires are clamped together between the balancers?
they comunicate with the esp not each otherhow do BMS and JK Balancer communicate ?
thru the interface. the interface thake data from jkbms on serial and from jk balancer from can .how do BMS and JK Balancer communicate ?
do u write to me un whatup?I have the battery ready, the JK app shows 3 Bluetooth addresses, 22 cells each.
How are the blocks put together?
Does 5.1 work with HV setup?I upload last version for DIY boards 5.1 bugs on rs485 connection was fixed
JK_BMS_BLE_SERIAL_V5.1.0 - 0x10000.bin
drive.google.com
Serial 1 - Serial BMS connection
Serial 2 - RS485 BMS connection
if u have more battery module and want to use only 1 interface u can override the max charge current and max discharge current for all pack.
Data send it to inverter can be see and verify in info page
From here project will be migrated to LILYGO T-CAN
If u want to support the project can buy the kits from my Ebay & PayPal
wifi pass is chipIDHi @mrconstantin
I will try use you solution with goodwe gw10k-et and 2 jkbms.
That new firmware v5.1.0 wants wifi pass to connect.
on 4.3 version i have chip id: db32a7b0
Hi, i have battery which are used in VW - LG-CHEM (PN 0Z1915 599 H) 6.85kWh / 234Ah / 29.6V - 8s3p - 6 pcs and 2 jk-bms jk-b2a24s15p-cwifi pass is chipID
et is hv invertor u need hv battery
I don't know if it is enough to use wit gw10-et. it need minimum 180v to work. if it will be not enough i can put into string another set - 3 battery and jkbms.
yes,ok, but then i need 3rd jkbms, it has max 24s. is possible to test set 3,75V and load it to let say 4V? of course capacity will be small, but to test funcionality will be enough?
to cut the pack from the invertor u have external switch.so, better use one jkbms + 2 jk balancer? As I understand, only 24s will be under switch control of jkbms, rest i need have external switch - maybe related to jkbms. jk balancers will be connected to jkbms by cam, and all information about whole set will be from jkbms.
Hi,
I will present my DIY CAN BMS emulator project , I work from some time to make this interface for integration of DIY battery with different brands of invertors with supported CAN or RS485 communication.
Interface use an esp32 with one or tow CAN ports and RS485 support, can handle multiple JK as inputs for data, and also cand handle LV or HV.
I use in this project all the data i can find online, i know am not the first on this road if u have documents of other BMS protocols u can share it with me.
If u want u can support my work to add more protocols to this project and buy the hardware components kit from my ebay or fallow on Patreon!
Hardware:
Esp32 DevKit 1
CAN : SN65HVD230
RS485: Max485
DC-DC: XL7015
RJ45 Breakout
Optional: Indicator LEDs
Connectivity:
WIFI Web Portal with Cell Info Data on local IP
Input BMS supported:
JK BMS - TTL, BT , CAN
JBD BMS - BT connection
Daly - work in progress
Protocol Emulated:
General BMS LV
Document V1.4 - 07.09.2020
CAN: 500Kbps
Transmission Cycle: 1s
Data Mode: Little Endian
Pylonthech LV
Document V1.2 - 08.04.2018
CAN: 500Kbps
Seplos LV
Document V1.0 - 08.04.2018
CAN: 500Kbps
LG Resu LV
Document
CAN: 500Kbps
Growatt LV
Document V1.04 22,02,2019
CAN: 500Kbps
Data Mode: Big Endian
SMA LV
Document V1.0 - 07.09.2020
CAN: 500Kbps
Li LV
Document V1.0 06.01.2020
CAN: 500Kbps
Victron Nemea200
CAN: 250Kbps
Pylon HV
Document V1.18 30.05.2019
CAN: 500Kbps
GoodWee HV
Document V1.3 31.03.2021
CAN: 250Kbps
BYD HV
Document
CAN: 500Kbps
Pylontec RS485
Document V2.0 15.10.2019
RS485: 9600bps MODUBUS ASCII
Transmission Cycle: 0.5s Timeout
Seplos RS485
Document V3.3 21.08.2018
Inverter Replay:
Growatt RS485
Document V2.02 24.07.2019
BYD RS485
Document
RS485: 9600bps MODUBUS RTU
Transmission Cycle: 1s Timeout
Inverter Tested LV
Victron: Gx Family - General LV have the most information displayed, this is an combination of more registry i find.
Growatt SPF 5000 ES - Pylon LV, Seplos LV, Li LV
Growatt SPH 5000 TL - Pylon Lv, Seplos LV, Li LV, Growatt LV
Solis S5-EH1P6k - Semplos LV, LI LV
Deye SUN12K-SG04 - Pylon LV, LI LV
Inverter Tested HV
Fronius Primo 6.0 Gen24 - BYD HV
SunGrow SH10RT - BYD HV
GoodWE GW10K - GoodWee HV, Pylon HV
ThinkPower S100TL - Pylon HV
MultiPack:
If u have 2 packs with 2 JkBms u can combine data by connected 1 to Serial Port and one on BT Port
If u have more then 2 u need to use more interfaces. The Rs485 will be use to communicate between interfaces and Master CAN port will rapport to bms.
Know Issue:
1 - When u use BT connection u can not connect with the phone app to the JkBMS.
U need to stop the interface power and after connect and make settings with ur phone app.
2 - Pylontech LV - if u use this protocol some inverter limit max charge voltage under 54V for 15S LFP battery.
Use Seplos LV or LI LV protocol is same as pylon with few data changed.
3 - From RS485 Protocols i tested only Fronius Gen24, The Pylon RS485 LV and Semplos RS485 LV are write from documentation for PC App -> Battery communication protocol.
Warranties:
The project is under develop NO WARRANTIES are provided ! USE on ur own RISK!
Software:
In this moment GitHub Repo under construction!
Download & Install:
U can download the bin file from my Google Drive Link and write it on ESP32.
For first install u need to be done with cable an pc, after that u can update the firmware OTA.
i will provide new update as soon i can!
JkBMSCan - Google Drive
drive.google.com
Support my Work:
If u like this project and want to support my work to add more protocols u can invest ur time and also if u can spare some $ will be great too!
Invest Time:
Test the interface on ur inverter and confirm what protocols are compatible to increase invertor compatibility list.
Provide documentation or data communication logs from ur Inverter and OEM battery for reverse engineering new protocols.
Share data if u all ready make some progress on reverse engineering new protocols.
Invest $:
Donate by PayPal and U will receive tech support for ur project!
Fallow on Patreon for last updates.
Buy components kit from my ebay for ur projects.
Documentation:
I share my protocols documentation folder if u want to make ur own software.
if u have any other document of interest share it also with me.
drive.google.com
Other Projects :
WifiManager https://github.com/tzapu/WiFiManager
TeslaBMS https://github.com/collin80/TeslaBMS
JKEnuPylon https://github.com/botaneta/JKbms_Emu_Pylon
JKBmsToPylonCAN https://github.com/ArminJo/JK-BMSToPylontechCAN
VictronLibCan https://github.com/jmibk/BMS-LIB-CAN-Victron
Implementation of this interface on battery:
LV 14S 180A Li from Kona with JKBms 150A and Can interface
HV 23S / module 60A from Kona with JK Activ Balancer and Can interface
JK - Victron
JK - Growatt
JK - Sungrow
ONLY 10 Pics for post SORRY!
IF U WANT TECH SUPPORT JUST WRITE TO ME, OR WHATUP!
Very nice work !!, I am struggeling to get my setup working. I have a DIY 16S 48V Battery with a DALY BMS which does both RS485 & CANBUS; it can emulate different CAN setups. My inverter is a NEDAP / Solar Frontier Power Storage ; which also has a CAN bus (got a few of them, hence my desire to get them to work ) , but will only work with the following batteries / BMS:Hi,
Hardware:
Esp32 DevKit 1
CAN : SN65HVD230
RS485: Max485
DC-DC: XL7015
RJ45 Breakout
Connectivity:
Protocol Emulated:
General BMS LV
CAN: 500Kbps
Pylonthech LV
CAN: 500Kbps
Seplos LV
CAN: 500Kbps
LG Resu LV
Document
CAN: 500Kbps
Growatt LV
CAN: 500Kbps
SMA LV
CAN: 500Kbps
Li LV
CAN: 500Kbps
Victron Nemea200
CAN: 250Kbps
Pylon HV
CAN: 500Kbps
GoodWee HV
CAN: 250Kbps
BYD HV
Document
CAN: 500Kbps
Pylontec RS485
Seplos RS485
Inverter Replay:
Growatt RS485
BYD RS485
Document
Inverter Tested LV
Inverter Tested HV
MultiPack:
Know Issue:
Warranties:
Software:
Download & Install:
drive.google.com
Support my Work:
Invest Time:
Invest $:
Documentation:
drive.google.com
Other Projects :
JK - Victron
JK - Growatt
JK - Sungrow
LG resu HV not same LV,Very nice work !!, I am struggeling to get my setup working. I have a DIY 16S 48V Battery with a DALY BMS which does both RS485 & CANBUS; it can emulate different CAN setups. My inverter is a NEDAP / Solar Frontier Power Storage ; which also has a CAN bus (got a few of them, hence my desire to get them to work ) , but will only work with the following batteries / BMS:
LG Chem
RESU 5.0
RESU 6.4
Akasol
neeoQube
neeoRack
Sony
Olivine ESS
BMZ
ESS 7.0
Saft
Intensium Home
From your list above, I see that the required batteries / BMS above are not supported ? Or would the LG CHEM RESU 5.0 be same as LG RESU LV ?
From somebody else whom sniffed the CAN port on the inverter, please see the telegrams the inverter requests over and over ;
Also indexes are requested
00 10
09 10
0A 10
02 20
01 20
03 20
04 20
Thanks in advance for your reply !
Thanks for your reply, I do have a bunch of Rasp Pi's and Uno's but ESP32 is new to me. Will order the parts you listed and build the setup and let you know once I have got in all in place and connected. Thanks for the help.LG resu HV not same LV,
If u hae some esp32 and can tranciver i can programe some "fake" data protocol to test on ur inverter
