cs1234
Solar Wizard
- May 9, 2022
- 2,302
Depending on the size of the inverter plug you need, you could use this, it's supposedly even UL approved, to go through the garage to the house.This is actually one thing I'm considering. Right now, I'm trying to understand which wires to put where. For example, do I put the solar generator in the garage and run a connection from the inverter through the wall of my garage into the house. Or do I instead keep the generator in the house and run the wires from the solar panels through the wall and into the house.
I'm not sure on the solar panels wiring through the wall, from what I can tell you have to put in all the regular solar panel crap, rapid disconnects, switch it from solar panel cable to a junction box, etc..
