javy105
- Dec 2, 2022
- 9
Hello. I bought this step up/down converter and I wanted to know if I could connect it’s input to the output of a Growatt hybrid inverter. I want to use the converter as it is, just the front receptacles. It’s going to be off grid and not wired to a residential panel. I ask since the input of the converter is a standard US 110v plug and not a EU 220v plug. I know the is an adapter to convert it to a 220v plug but the Growatt output only accepts bare wires. Can I cut the plug off and use it’s wires? If so, which colors go into the L-N outputs of the Growatt’s? I know both are hot wires coming out of the Growatt since it is a 240v inverter.
