BananaPeel
- Jul 24, 2022
- 5
I'm planning to have 6 x 400W panels on my RV roof. They have a nominal voltage of 42V. I also plan to have a 48V battery bank. I had wanted to avoid running any wiring much over 50V anywhere. However, all the 48V All-in-one chargers/inverters I can find call for an MPPT Voltage range starting significantly higher than 42V. The lowest I can find is 60V with many requiring at least 120V. I could wire enough panels in series to meet those requirements. However, I'd rather not because I'm concerned about getting as much power as possible in shady conditions. I'm also concerned about the safety of running that high of voltage through my RV, especially across the roof.
So, should I change to a 24V system? Are there any good 48V AIO units that are usable with a 42V solar input that I'm missing?
Or, Is there any way to connect my panels in series, but still only have cables running 42V across the roof? In other words, connect them in series in my Inverter compartment, but have all the wires from the panels stay lower voltage across the roof and down the walls until reaching that compartment. Of course, this wouldn't solve my issue of wanting all the panels in parallel for shady conditions, but it is better than nothing.
Or am I just making a big deal out of nothing and need to go with a 48V system and hook the panels up in 1-3 series circuits?
