justinm001
- Dec 18, 2022
- 1,534
In my RV chassis system I have 4x lead acid batteries running series/parallel to power the 24V engine and aux loads as well as each 12V side runs all the electrical components. The system uses a 100a Vanner equalizer like below to keep the batteries in balance.
Why can't I run something similar for a 48v lfp system? Isn't it the BMS's role to accept voltages and then it equalizes each cell? Say I want to have 2x 48V batteries in parallel then have 4x 12V batteries in series connected to those 48v batteries all using a large charger. As long as the charger is running at 57.6V it should be recharging the 12v batteries in series as they're at 14.4v.
When not charging the 12V batteries are draining separately but the other 12V batteries in series should pickup the voltage and level it out, while the 48V batteries also level it out? Or would something else happen since LFP batteries don't drop much voltage when discharging, hence the need for an equalizer like that Vanner?
What exactly happens if you connect a 48v battery at 10% to another 48v battery at 100%.
I'm also curious what'll happen if one of the 12V batteries is down to 20% while rest are all at 90% then we get a trickle solar charge. Would it charge each battery evenly or would the 12V take most of it.
