Piet_de _Pad
The sun: a free natural large nuclear reactor
Dear reader,
I want to connect a small generator of 3KW to a house with a split phase grid, using an ATS to isolate the house from the grid.
This is what I know from generators, and correct me if I'm wrong. Small generator do normally have two 120V outlets "A" and "B" and one 240V outlet "C". The stator of the generator has normally two coils each for 120V and these two coils are connected in series to generate the 240V. The way the outlets are connected to the coils is depicted in the picture below.
This is my question. Without modifying the wiring of the generator, I want to add a split phase connector "D" to the three Connectors AB&C that I have. I want to do this by taking the two phases of the two 120V wall outlets A,B and use the neutral connection on the same outlets A&B as the neutral of the split phase.
My question: are small generators always made based on the schematic I show and can I make my split phase as I describe in the text.
Thanks for the help
Thanks for the help
