TonyRumore
- Dec 13, 2021
- 8
I have a pair of Victron Multiplus Inverters running 240 volt split phase to my Cabin's panel. (Offgrid system)
If I were to connect a 120 volt (single hot line) generator to the system, should I just hook the one generator hot line to one of the inverters, or split the wire into two, and run a hot line to each of the inverters? I also have a 240 volt generator, and I assume that would have one hot leg going to one inverter and the other hot leg going to the second inverter. Is that correct?
Tony
P.S. Been a lurker here for a couple of years. Installed my whole system, thanks to you guys and Will's youtube vids.
Tony
