Too hot for howlers
AGs ask Supreme Court to block climate change lawsuits
Opinion: Considering the oil companies can afford OJ quality lawyers the only way they can lose is if the evidence is solidly against them. If the evidence is that solidly against them and they lose the cost gets passed to the consumer, which makes alternatives look every better.
LCOEs are already on par with the cheapest form of fossil fuel, so is this move just to keep oil companies in power?
That article seems to point back to the same paper, doesn't look like a confirmation of a second paper.
My personal pet theory is we killed them. But, I think your point is if you look hard enough you can find a paper on anything and that's why consensus is better than one offs. Let's test that... Yup...
New theory for Neanderthal extinction that confirms my pet theory! ; -)
While the basis of Bob's paper points to a mass extinction, the general consensus (much to my surprise) seems to be that field changes don't cause mass die offs.
Well, the ice core samples mentioned in that paper were from Greenland and disproved their theory. The paper you cited was proposing an alternate to the accepted theory. Computer simulations, well...as so many are fond of saying about the IPCC, Garbage in, garbage out. They did have a lot of caveats listed to make the events match (although in geological terms the numbers are all bound to come snake eyes eventually). Data from caves... you mean the cave paintings? What exactly did the cave paintings prove?
UV does indeed depleted Ozone, but the magnetic field doesn't block UV; so a weakening of the field wouldn't increase the UV. only charged particles like electrons or protons are bent/deflected when travelling through magnetic fields. Even the paper you provided had a more complicated chain of events regarding it.
Theories to explain events get published all the time. Not that most care what why the Neanderthals' went extinct 42 thousand years ago.
Interesting. Why do you think that? Is it true cows emit methane? Yes it is. Is anyone anywhere in the world currently managing cow farts? Why no, they're not. Is anyone talking to countries about their GHG emissions? Why yes, they are.
You're a logical guy. So the question becomes, how did that emotional claptrap argument get into your mindset?
It is true people are looking at ways to mitigate methane from Agriculture. It is true that some countries are showing us the middle finger given we've created a rich country by polluting the atmosphere and are now telling them they shouldn't do it. But it is not hypocrisy to state facts nor is it hypocrisy to work on multiple things at once.
Actually, we would be doing something. Every little bit of reduction slows it down. Ditto EVs, heat pumps, better insulation, heat reflective paint, working on reducing emissions from products like concrete and steel, and even (grumble grumble ; -) removing GHGs from the atmosphere.
But is the magnetic field switch causing climate change?
NASA: Why Variations in Earth’s Magnetic Field Aren’t Causing Today’s Climate Change
The results in Bob's paper says their modeling shows climate change would have been in the mid latitudes. That's the opposite of what we observe with global warming today.
But, if the theory is correct in Bob's linked paper, then we might see additional warming on top of the existing man-made warming from GHGs as the magnetic fields are indeed fluctuating and may (or not) flip polarity as it has countless times in the past.
