Can this be made to charge Ecoflow Delta 2 when battery is full. SmartSolar MPPT 75/15
atvuornf
Van has 175w panel, once house battery is charged energy is wasted, can this controller be made to send excess charge power to Ecoflow Delta 2, through the load connections via the included Delta charge lead. Mppt is next to my power station. Van has one AGM92amp hr battery.
Better to have a switch so you can route your solar power to either the 75/15, or to the Delta 2 via the xt60i to mc4 cables. Perhaps two imo style disconnects?
Yes you can easily
Connect the load terminals from the Victron to the XT60i input of the Delta2 via an on/off switch. Turn switch on when battery is full.
Leave the battery connected to the SCC.
What is your charge controller brand? If it's Victron then check out the load settings and change it to user defined settings. Change the "on voltage" to something like 0.1v lower than adsorption voltage. So it turn on the load ports when batteries are almost full. And set the off voltage to the float voltage. So that the mppt atarts charging if the battery voltage falls below the float voltage. Change according to your battery type and play with the settings to see what works.1000264174.png
