Shivam32193
Hi, I need to design 25MW ground mount system. Please any one suggest whether to select Central inverter or string inverter?
A DIY 25MW system? I hope you have a neighbor to help you mount the 50,000 panels.Hi, I need to design 25MW ground mount system. Please any one suggest whether to select Central inverter or string inverter?
Sol-Ark 60K is hybrid. OP might not need battery charge. Deye (=Sol-Ark manufacturer) makes GTI string inverters more than twice that size. Still ~180 string inverters vs 50 bigger string inverters (=central).![]()
Solar Power Systems: String Inverter or Central Inverter? | Novergy Solar
The pros and cons of string inverters vs central inverters for solar systems. Learn which one suits your needs best for optimal power output.www.novergysolar.com
Largest sol-ark (string inverter) is 60kW.
Largest central inverter is 500kW.
50 central inverters vs 417 string inverters for 25MW, I would go for central.
Tigo optimizers for panel level monitoring?
YesCentral inverter or string inverter?
What solution did they come up with?Thankyou for your valuable comments.
I got my solution from OEM vendors. I thought here people are mature enough to answer or discuss.
Hi, No going for 3.3MW central inverter. And yes central inverters are better and convenient![]()
Which town you dwell? In INDIA we have lots of moneyThis poll should read:
School project?
Or
DIYer with tens of millions of dollars to spend?
Nope, we just had a school project here asking essentially the sane nonsensical question, with the same apparent understanding of the terminology.Thankyou for your valuable comments.
That might be silly for you, not for all. Get some air kiddoNope, we just had a school project here asking essentially the sane nonsensical question, with the same apparent understanding of the terminology.
“Ask a silly question, get a silly answer.”
Not DIY, its a tender.A DIY 25MW system? I hope you have a neighbor to help you mount the 50,000 panels.
Sorry, I misspoke, that should read “Billions of Rupees to spend”.Which town you dwell? In INDIA we have lots of money
Ah, you want the SillyQuestionsForTenderSolarForum.com website then.Not DIY, its a tender.
Why you getting personalIf that is the case then this isn't the place for you. You should working with one of the below firms.
