BMS8TSmall question: is there a datasheet of some sort for the BMS?
I have made it clear time and time again that these things leave a little to be desired. But also I have also found them to do what I need them to do at a reasonable price.Say what?
Not standing on any "high horse"
Just presented the facts on Chargery current measurement and AH calculations.
I get the feeling YOU, as a seller of Chargery hardware, sound a bit disgrumpled.
Don't shoot the messenger!
What irritated me is you said you knew how to take care of batteries. I'm sure that's true but why wouldn't you check the voltage now and then?
I agree with craig on this one ..... I have known about the SOC deficiencies in the Charger for some time now .... but still intend to use it because of all the other things it does that I want it to do ... and it seem reliable at doing the protections I want.
Now .... if I had known this BEFORE I bought the Chargery would I have still purchased it .... probably. The only other BMS that I have seen that doesn't break the bank and has similar functionality is the Electrodaucus and the strategies recommended by the developer kinda make my head spin.
All I asked is if the LVD didn't work. Then you got defensive and stared you knew how to take care of batteries. I was wondering if there were another issue. No bait and switch here.My batteries are not issue. Please don't make it the issue. I regret I mentioned them. However you seem to see it as carelessness on my behalf and want to jump on it. You have also made it personal. Bait and switch?
The problem isn't that the BMS is doing that (well it kind of is for some people), is that there's no mention at all of this behaviour. So you buy it and expect it to work normally and not have this weird thing. If it was mentionned then you can make an informed choice and still buy it, or not buy it.
I have made it personal when you started attacking my character.My batteries are not issue. Please don't make it the issue. I regret I mentioned them. However you seem to see it as carelessness on my behalf and want to jump on it. You have also made it personal. Bait and switch?
Yes cell inaccuracies are not acceptable. The issue should be resolved by Chargery or the vendor without any cost to the buyer. I have already exchanged 1 or 2 that I sold.I agree ... That is the reason I have posted my experience with Chargery SOC inaccuracies in a couple different threads. People need to be making informed purchases.
A couple other observations .... I wish that Jason would post his response to this on the forum instead of sending an email to CAL .... but I also wish that CAL had gotten his permission before posting the private email. I understand his frustration with the situation and he is even trying to build his own coulomb counter.
I think the inaccuracies with the cell voltage readings some people are having is a worse problem than the SOC problem. A VERY big part of a BMS function is to provide cell level protections ... those cell level protections and balancing functions are based on cell voltages. (I don't have a problem with cell voltage readings with my BMS8T)
I moved on from the SOC shortfall .... just decided to deal with it a different way. That doesn't mean I am happy with having to buy other equipment in order to get good SOC tracking. With my BMS8T, I don't have a problem with cell voltage readings.
No, it started with the high horse comment.I have made it personal when you started attacking my character.
You are correct. I was trying to help and you said you knew what you were doing. Good luck.No, it started with the high horse comment.
I agree it leaves some to be desired. I have never used the shunt. I use it by going by voltage alone and it seems to be about right but then I have never actually compared it to anything else.Hey, it's no fault but my own what happened to the battery. Never blamed Chargery that the battery discharged to zero volt. I did mention the SOC display is a disaster though. I'll stand by that.
Please don't comment on something you have no knowledge of. I certainly did ask Jason if his message could be posted.
I asked him but he didn't reply.
