This not a "charger" by name but will charge a battery. If you are using lead acid, this is less than ideal but will work. Lead Acid need to be charged to a voltage and then held at that voltage until "fully charged". This power source doesn't know if the battery is charged or not. If the voltage out is set just below your ideal full charge voltage, the current will taper toward zero as the battery is fully charged. If you get the voltage a bit higher, a little current will continue to flow even when the battery is fully charged. This is not what you want. If you can charged the battery to 95% and disconnect when it is charged, you can use this. If you want to leave it on charge unattended for hours and hours, a real charger would be a better solution. This is a simple solution. You might find a normal plug into the wall 24v charger but the cost might be more to get similar amps output.
