I'm in the process of building battery packs of 18650 cells. Each pack is / will be 30p13s. That turned out to be a suitable for filling the stackable fire proof storage boxes. Now I got the idea that it would be convenient to be able to pull one pack out of the house bank, hook it up to an inverter and use it as a mobile "generator" for power tools. I'd like it to be a part of the house bank most of the time, just that I'd like to be able to pull it out those days I need it other places.
The challenge is, how do I reconnect this thing to the house bank? Most times when the mobile pack has been away it will return in discharged state. While this pack was away the rest of the house bank has been charged by the solar. Hence the voltage difference may be as much as 10V. Just connecting the cables directly I think would make a dangerously fast recharge. Hence there is a need for some kind of controller between the house bank and the mobile pack. What kind of controller should that be? Would a constant current circuit do the job? Or a current limiting circuit? Would a pwm motor speed controller do the job? When searching for "constant current module", lots of the hits are pwm motor controllers.
What makes this different from most charging circuits is that:
1) both the source power and the battery being charged will accept dangerously high current unless limited. Circuit must have a current limiting functionality.
2) the target battery voltage when charged is the same as the chargers input voltage - which is variable!
And what happens the day the mobile pack returns home without being used (still fully charged) on a cloudy day (house bank discharged), hence the voltage of the mobile pack is higher than the house bank?
My plan is that when the mobile pack has reached same voltage as the house bank, I will disconnect the charging circuit and connect the mobile pack directly to the house bank.
