Charging 48v LiFePO4 battery with 52v Li-ion charger?
Awoo
Hello friends, I'm about to build a 48v 16s5p LiFePO4 battery but I don't have a charger specifically designed for this chemistry. Would it be safe to use this charger designed for 14s Li-ion cells?: https://lunacycle.com/luna-charger-52v-advanced-300w-ebike-charger/
It can charge Li-ion batteries to 90% of 58.8v which is the setting I intend to use it at, but if the charge voltage of the charger is a constant 58.8v and the charge voltage of the 48v battery is 58.4v, will there be a problem? Can I charge to 100% and just rely on the BMS to cut off charging at 58.4v? Will my 48v Daly smart BMS even accept the voltage, or are there some settings I could change? It seems like a 0.4v difference wouldn't be that bad but I want to be certain that I'm not harming the cells/BMS.
I couldn't get a clear answer about the charging voltage of the charger so I'm not even sure if it's a constant 58.8v until I connect the battery to it. Without a load it outputs 58.4v, which seems perfect. Do Li-ion chargers usually work this way?
Thanks for the help :)
snoobler
Solar Honey Badger
Moderator
Welcome to the forum.
At 58.8V, most Li-ion is at true 100% (4.2V/cell).
58.8V for LFP is at 3.675V.
If you already have that charger, and you have a BMS installed with suitable high voltage protection, it's fine. I would personally use it in that situation.
58.4 vs. 58.8 might be calibration error between your meter, the charger or both.
Burke
If you haven't bought a charger yet, why not get a charger that is set up for LiFePO4 right from the beginning then you don't have any charging gymnastics to deal with?
snoobler
Solar Honey Badger
Moderator
80% should be ~56V and 90% should be ~57.4V, only the 100% setting should be 58.8V.
In the context of LFP, the above recommendations are not absolute. SoC at a given voltage depends on C rate. 5A on a big battery will get it very full at lower voltages. One can obtain 95% SoC @ 54.4V at low current.
BlueFox
Sorry I should have made it more clear in the reply, I meant in regards to what the charger should be outputting for a li-ion battery pack since that's what it was made for.
snoobler
Solar Honey Badger
Moderator
I wasn't sure, so I added the context. :)
We are in agreement.
