robbob2112
Doing more research, mosty harmless
That is one of these - 2 post MRBF fuse - 175amp MRBF to the inverter - 20 amp to the MPPT.
Technically the MPPT can do 100amps, but I only have panels enough for 9.54 amps. The fuse is for a cut in the wiring verse a problem at the solar. And - I also have a metal combiner box for my 1 string that has a SPD, main breaker, and a 15amp breaker for each string. I can add 4 more strings later.
It is still a work in progress since I just got the all but one part yesterday. Going to string 3 x 335w panels in series for a Voc of 126v and 9.9amps
panels in parallel - voltage the same, current adds.
panels in series - current the same, voltage adds.
My panel Voc is 42v with 9.54amps - I actually have 4 of them, but 1 is hooking to another battery at the other end of the house with its own MPPT. Similar setup but smaller.
