I have a portable 130W solar panel with an SAE plug at the far end. What I want to do is plug this into a 12V car throw blanket (enabling me to use the blanket while the car is not running). The blanket draws about 45W. If I were to just use an SAE-female 12V wire like the one below to attach the two, would this work or would I fry the blanket? These are inexpensive components I'm trying to find a use for, if my only option is to add $200 of other bits and pieces, there's no point. Thanks!
Edit: A related thought on this, can I use a cheap battery controller without an actual battery - in other words, we go solar panel --> cheap battery controller --> 12V socket (which will draw what it needs depending on what's plugged in).
