Ground Bushings on Raintight Couplings?
jmoles
Maryland
I'm connecting EMT into the plastic junction boxes and my understanding is I need to use grounding bushings because the box is plastic and the EMT needs to be grounded.
Problem is I don't have enough neck on the Raintight connector to screw the bond bushing on. If I take off the lock nut then the bond bushing will screw on but there's no lock nut and it can't be tightened.
I have these sort of ground bushings.
Did I need to get grounding lock nuts and not bushings or is there some way to make the ground bushings work?
