Ampster
Renewable Energy Hobbyist
The conversation with @L Hunter has always been about J1772 Type 1 connector.What , J1772 connector known as type 1 is good for split phase to 80A.
Yes he is.This is assuming the OP is in the US.
If you go back through the conversation you will see that L Hunter has not picked an inverter charger yet and the connection from that to a proposed EVSE adapter has been the conversation with him. These adapters come with a female socket that would need to match the plug attached to the invlerter charger. Do you have a different approach that would be simpler for him?There is no connector change needed it’s all the one J1772,socket.
