2TrevorJ
Bend the Joules
So, Jasonhc73 on here posted on a (different) FB group about Emporia's EV Chargers and their "Excess Solar" function that charges only when exporting and dynamically adjusts current to match export (until pegged).
I jumped in based on his recommendation and purchased one of their chargers and a VUE Gen 2 energy monitor to feed it export info and holy crap...it works!. I armed it last night and this morning once my house ESS battery was full (from running the house overnight) and export started the Emporia system watched the export for a bit then fired up automatically; ramping up output over ~9 minutes to the max my car would accept. Later in the cycle the sun went away for 2-3 minutes and the Emporia modulated EV charging current to maintain a slight export through the power reduction. Once the clouds cleared it went back to max automatically until I shut it down when the car hit 82% (where I normally stop).
I'm not sure if I believe it but I found some info that Emporia learns your system's normal export pattern and makes some assumptions about when and how much charging current might be available. Sounds like it won't be so hesitant to watch the export for 3-4 minutes then ramp slowly like it was with my first use. Again...sounds like some advanced stuff so it could be marketing.
Now, one kicker is I run my house off battery whenever solar isn't sufficient and as such I believe there is a possibility that as the sun goes down or a cloud passes overhead and my export nears zero the EV could keep charging because the power just keeps on coming; slowly transitioning the source from solar to my house's ESS for power. To get around this I figured out that I can set the max ESS battery draw during the EV charging window to <240W (1A @ 240V - one "unit" in the charger's adjustment range) so that the effective power will decrease and the EV charger will step down 1A at a time until it shuts down when it sees <1440W available (6A @ 240V - the minimum the charger can run at). With this you might have to pull a bit of grid if there's a spike in home load but it's the best thing I could come up with. ?
Sure beats watching production and manually starting/stopping the charger to keep from dumping my ESS's juice into the car (or turning off/on TOU).
