I was considering these batteries for my system. Which BMS would you need to use?
Spend some time poking around the BMS subforum. There are a handful of considerations to consider when choosing a BMS, the cells you choose isn't really of much concern to the BMS.
The first things you need to determine are:
- How many cells will be connected in series 4 (12v), 8 (24V), or 16 (48V)
- What is the maximum charge and discharge current of your system
Then, you can narrow your search down to BMS' that meet those parameters
The essential and fundamental role of your BMS is 'cell level' monitoring and protection.
Generally speaking the 'big 5' duties your BMS will perform are:
- Overvoltage protection (protect your battery from being over-charged)
- Undervoltage protection (protect your battery from being over-discharged)
- Overcurrent protection
- Cell balancing
- Low/High temperature protection
Then there are many optional 'nice to have' functions:
- Bluetooth
- SOC monitoring
- various communication features
- granular control and user configurable settings
- etc
The Daly BMS is the most basic, simple, straightforward BMS popular around here. It does the bare minimum of what a BMS needs to do and literally nothing more (Items 1-4 on the 'big 5' list). Its a good option if you want to build a simple system, and don't need low temperature protection.
The Battery hookup BMS does everything on the 'big 5' list, has bluetooth, and user configurable parameters, its more complicated than the Daly, but enough people use it that you should be able to get help if you need it
The chargery BMS is the most full featured and advanced with the most bells and whistles, including state of charge monitoring, it is the highest quality of the three but its also a bit more complex. It lacks bluetooth (coming soon apparently), but otherwise has all the features mentioned in both lists.
The SBMS0 is another full featured high quality option but for advanced users only.
