dtbaker61
I am working on designing a residential off-grid system.... to be installed in a reasonable sized mechanical room off a garage. I'm planning on a EG4 battery rack with 4x EG-LL 48v LFP batteries.... and since the cabinet is not very tall, I am considering fabrication of a 'inverter stand' to bolt on TOP of the battery rack to minimize the footprint of the system, and hopefully save time versus hammer-drill and expansion bolts into the concrete wall I would otherwise have to mount inverter on.
In new mexico all residential solar MUST used UL listed equipment, be permitted and inspected....
The batteries are UL, inverter is UL.
My question is.... if I drill holes in top of the EG4 battery cabinet to bolt on an inverter 'stand' so I can install the inverter on top of the cabinet, will it violate UL listing, or building code? Our local AHJ is using NEC 2017, but soon to be NEC2020.
