I'm as big a coffee snob as you find, roasting my own beans and a have a commercial espresso machine on the kitchen counter, but when I'm off grid it usually means there's fish that need catching. No time for all that messing around. Boil the water on the stove and dump it in the thermos with some instant Maxwell House and I'm out the door.
Be careful about those coffee and fish tales. LOL The right coffee can make a difference and the fish seem to know. I once caught a fourteen pound crappie after having some of my good custom roasted coffee.I find the fish are easier to catch when I've had a good cup of coffee, sitting down to a nice breakfast. I know there are rhythms to optimal times to catch the fish but I'm in no hurry. I'm a shore fisherman, so the less I carry the easier it is.
jura coffee makers are in the top 3Hey Guys!
What is the best available coffee maker with a thermal carafe nowadays?
I'm using a Canadian brand Oster Coffee maker which is exactly the same product as the Mr. Coffee brand which I believe is sold in the US. I have been using it now foe several years, and I have had a replacement one since last Winter. I recently noticed a strong plastic smell from the water container and I strongly suspect that it contains BPA. I want to discard the product for my health sake and I'm looking for a dependable replacement that makes good tasting coffee. I like dark roasted coffee as is, black without any sweetener.
I have been looking on the web through Google and I got several different recommendations as we usually find when we do such research. Two brands that frequently best coffee maker under 100 dollars come out in the several lists of recommendations are ZOJIRUSHI and NINJA. I know that Zojirushi mentions that their water container is free of BPA, but I'm not so sure about the Ninja product. Of course, reliability is also important.
So, would any of you, coffee lovers, have a recommendation for a reliable product that makes good tasting coffee? Your comments would be appreciated.
Anyone else using ultrasonics?
Found this earlier post.My wife & I were taking a multiday class long ago and one of the agenda items was to demonstrate our proficiency by doing all the provisioning/cooking. In the morning our instructor invited us to have some of his "cowboy coffee" (grounds boiled in water - guess he didn't trust us and brought his own supplies). We said no thanks, and invited him to some our gourmet coffee. The wife loves to cook and you sure don't want to mess with her coffee. I doubt our instructor ever ate so well while giving that course; what she could do with the limited items available was amazing.
thank you so much for your suggestionI thought most people in the back woods just re-purposed one of their old stills to make coffee. LOL (most serious back woods folks just start drinking shine again in the morning and just skip the coffee)
FYI, I roast all my own coffee. Green beans keep forever without refrigeration, roasted beans do not. Worse yet are the roasted and pre-ground coffee's sold in stores. Now all though I use an electric roaster that was made for that purpose, lots of folks have used air poppers to roast coffee beans. I personally don't like the results of air poppers. The old cowboys had been known to roast beans in a cast iron fry pan over a fire, a bit tricky but in a pinch it works. Grinding can be done in a hand grinder or a electric grinder sold about anywhere. Best to grind no more than 15 minutes before making the coffee for best flavor. Also, freshly roasted coffee beans need to sit for at least 8 hours before using them. Peak flavor is in about 2 & 1/2 days, and it goes downhill from then. I generally only roast enough for a week at a time.
Any of the "pour over" methods will give the best coffee. Stove percolators butcher a pot of coffee, and most electric types that don't percolate or heat from the bottom like a percolator do OK. There are lots of modern coffee makers under 1Kw too.
For the green coffee beans, supplies and some roasting equipment I have been using an outfit called Sweet Maria's. So far so good for quite a few years. There are lots of other suppliers too, and I used to go to a local roaster and get bulk beans years ago.
Will a 1475 Watt (max) K-Cup coffee maker work in my Airstream GT with the chassis motor running? I know with the 1000W inverter it won’t work with the engine off. My thoughts are ....no matter if the engine is running or not the coffee machine will trip the breaker. I don’t want to start the generator or have to be on shore power to make a cupAlmost sounds identical to our situation. Current cabin is 16x18 for 5 guys.
Outhouse, Propane lights, stove and furnace.
New cabin will be 24x36. Solar power with an inlet installed for running with a generator when it's not hunting season.
I'm framing in a bathroom and will eventually ad a compost toilet. We'll still use the outhouse in the summer, but it'll be nice using the compost toilet when it's zero or below zero outside.
We have a 55 gallon barrel for rain water collection. I have a bromine floater in there from an old hot tub so the water will be keep bacteria free. We'll use that for the make-shift shower and for washing hands etc...not for drinking.
when does dutch bros close
Good times!
Fixed that for you.There is no substitute for a good cup of coffeein the woods.
of coffee.
So, if I’m correct, I need to look for a coffee maker that draws less than 1000 watts. I prefer a K cup machine. Any recommendations?
A 1000 watt in inverter can only output 1000watts (plus maybe a little more for a short time), any more and it will fault. You need a 2000 watt inverter and associated wiring and battery upgrade to make that work. Our tecnivorm, 1500 watts, draws about 130 amps off the battery.Will a 1475 Watt (max) K-Cup coffee maker work in my Airstream GT with the chassis motor running? I know with the 1000W inverter it won’t work with the engine off. My thoughts are ....no matter if the engine is running or not the coffee machine will trip the breaker. I don’t want to start the generator or have to be on shore power to make a cup
of coffee.
How will I get any coffee early in the morning? My countenance is not bright enough to boil waterI'll just leave this here.
cheap 2000 MSW inverter and Drip coffee maker and done.How will I get any coffee early in the morning? My countenance is not bright enough to boil water
