Cheap 4-life
My body is 2.63 trillion volts, .07v per cell
In the video shown here
Can you share the video?
Surely they define the preload conditions somewhere in the document.
Preload is an engineering term. It applies to beams, bearings, springs, and lots of other things.
Just got the 20mmx10mmx80mm springs in the mailVery similar to what I purchased. These are also medium duty. 10mm gives a little extra room for 3/8 all thread. i got them 80mm (slightly over 3”) due to all the expansion my 19 cells in a row will have. However I really want to keep the expansion of each cell below .5mm, so no more than 8mm for my 19cell pack.
Look at table 7: https://mdpi-res.com/d_attachment/e...ploy/energies-14-01732.pdf?version=1616229789That’s seems rather fast to degrade to 80%.. that’s only 1825 cycles if it’s fully cycled everyday..
Although that study was of cylindrical cells, but I’d assume prismatic cells would be similar but degrading faster from calendar agingLook at table 7: https://mdpi-res.com/d_attachment/e...ploy/energies-14-01732.pdf?version=1616229789
Close to 24 years of calendar aging before cells degrade to 80% of rating as long as they were stored at 25C (77F) but that degraded to only 53.5 months / less than 4.5 years if those same cells were stored at 40C (104F).
So yes, assuming we are all using our cells at temps under 80F, calendar aging should not be nearly as much of a concern as cycle degradation…
It seems like you are suggesting that the newest EVE datasheet is crap. I can't download the paper you linked where I am right now. What was the date on it?There’s an amazing amount of good info out there, but every year it’s getting harder to find the cream out of the mounds of mostly crap background. It use to be so easy to do a search. Now it’s buried in incorrect results.
That paper is old, February 7, 2014. Probably some of the earliest aluminum bodied prismatic cells.It seems like you are suggesting that the newest EVE datasheet is crap. I can't download the paper you linked where I am right now. What was the date on it?
It's just that a huge portion of this thread discussed the new specifications from EVE. Showing that an upper pressure was considered bad eight years ago may not help. The whole question is whether an upper bound exists any more.That paper is old, February 7, 2014. Probably some of the earliest aluminum bodied prismatic cells.
Not implying that the EVE data sheet being crap. Just searching things in general.
Ever just wanted to get a torque spec on your car? Junk comes at you before the answer lol. I didn’t even know there’s a torque spec on the little blue pill ?
My read is that the new data sheet is how they tested a cell. Yes it can be done that way but it’s still not necessarily the best way. A high upper pressure from a completely rigid fixture is still imo not optimal for the cells.. My understanding is that starting our cells at 300kgf with springs or Poron foam is better than having them in a completely rigid fixture. Better as long as the cells are not allowed to expand to much. To much being anything over .5mm each.. I don’t see how the new data sheet changes that.. the springs or foam should also leave extra room to not compress the cells to much at high SOC. Rigid can’t do that. Also as the cells age they expand more (or whatever) causing more compression (or whatever) within the rig.. Springs or foam can accommodate that where as rigid cannot.It's just that a huge portion of this thread discussed the new specifications from EVE. Showing that an upper pressure was considered bad eight years ago may not help. The whole question is whether an upper bound exists any more.
I thinking that temperature is going to be the biggest issue in regards to calendar aging. If someone’s battery capacity is insufficient and they are being charged hard and heat is being accumulated within a server style battery enclosure, it’ll probably be a factor in the future. During the last heat wave mine got pushed hard for a few days but they reside under a bench top with an air gap. Luckily I was able to have a small fan on a timer to blow cool early morning air across the top which made a huge difference within hours to cool the mass down for a repeat heat and load.I think the cells are so similar that they should be treated the same. Fixture/compression of some sort should be done. Only argument was calendar aging would happen before cycles..
Thanks for sharing!This is my mock up of planned compression / drawing, will have 18 x springs in total ( 3S6P).
So far has cost £10.77 for the springshttps://www.ebay.co.uk/itm/Compress...a-e7d6-46cc-9b0e-f90b5ac460ca&redirect=mobile + couple of £ for the 12mm OD plastic pipe(sleeve on inside of spring to allow threaded bar to slide, plus on threaded bar along it's lenght to ensure isolation against cells) - all other bits are sourced from work for free? - hence why 8mm threaded bar - 6mm would be ok but none at work ?.
Spring rates chart is as tested under various compressed lengths, also compressed spring for a week to check for long term deformation and seems good.
So as far costs go- negligible, just a bit of time in man cave.View attachment 113409
Note - this is my take on a solution for compliance with requirment, you make your own minds up how you wish to build.
Just trying to understand / learn as much as possible to build my enclosure...EVE has shown you how you can get 6000 cycles to 80% of initial capacity by building a rigid structure.
9min into this videoHere we go again!
Good read that one, i know it's not Eve, so some might say irrelevant.Here’s the link to the papers,( chart is on pg32) lots of info;
Pretty crazy huh? Yeah, the right side where the blue line ends is probably where things got gooey. There’s not much difference between 10 and 12 psi, so I went with 10.
