Compress or not, flexible busbar or not
Just consider that McMaster has already compromised your p.c. with a cookie. If I don't allow them to do that with my making an account they won't allow me to even shop. You must have an account with them from the past. This corporate mentality deserves to be punished. I don't wish to offend you of course.
The company I work at does this too.
I mentioned this to the sales department but it fell on deaf ears.
If I can’t explore a site without enabling cookies, I’m out of there. A large percentage of people just don’t want more emails or junk in the system.
well I must say reading this thread hurt my brain, and for a good 20 pages or more people seam to not understand we are dealing with gas expansion not liquid expansion so now if compressed properly there will not be the movement people think as if the volume doesn't change with a gas then pressure and temp go up. if eve is telling me I can clamp it at such a force and at such a state of charge and temp I am assuming that when I am at 100% state of charge the pressure/temp inside the cell will still be at a safe range and it won't rupture the safety disk. the only thing compression is doing is keep the week middle of the aluminum casing from bulging a bit as it is weaker than the slight rise in pressure
now if it was water expansion from freezing then yes water is a non compressible fluid so you don't have that option for temp and pressure to increase to make up for the volume, what you get is a force/temp increase at a much higher magnitude, which is the principle of hydraulics.
now for a serious question, since we are dealing with air compression and the slight change in volume from a bulge is really minimal in the overall volume of the container, why do people still figure you need to use springs to allow the container to expand, when the whole point is to hold it constant and prevent that bulging is it not?
lets look at what I am getting at
my eve 304 cells are 173.7 x 72 x 207.5 mm so we will round up to make it cleaner and make it into inches to keep the numbers reasonable. so they are approximately ,so 7x8x3, not exactly but close enough so that gives us 168 cubic inches
so if we bulge the faces 2mm on each side it will be a curved surface and not a uniform change so it would be less than the equivalent of 1mm on each size but I'll keep it at 1mm to each side to keep it simple. that will increase the width by 0.04 of an inch so we end up with 170.232 cubic inches so that's a change of 2.24 cubic inches (probably actually less than that if i did the math for the curved surface.. but good enough). so if we left the cells unclamped, or clamped in a system that will still allow the cells to move what will happen is the pressure inside of the cell will remain more constant as the gas temp increases, by compressing them all we are doing is holding the volume ridged which means as there is more off gassing inside the cell the pressure and temperature will go up as the gas compresses but to figure out that difference there are a few things you need to know. the most important is what is the make up of the gas inside the cell as you need that to get some of the information we need. and there is still the problem of the cell not being a empty chamber most of the space is taken up by solids so that reduces the volume we are looking at significantly then we need to know the rate of off gassing there is due to charge rate and temp. its not as simple as people are making it out to be and since eve has given a diagram on how to compress the cell that's what I am going with, now weather its one or 4 or 8 being compressed the force isn't going to change as your not going to get any movement if you do it properly as all you are doing is restraining the containers and the 17inch lbs or what ever the number is... is just the number you can tighten it to before you are putting to much stress on the container and having a negative effect.
so in my mind by using springs or foam that will give you are defeating the purpose of holding the container ridged and not allowing that expansion, so aside from having something that keep them from sliding around in an earthquake what is it really doing? Also from reading, and I may have been reading something wrong so if I am off base let me know, but the compression factor is most important for the initial so many cycles say 4 to 10 is what I have been kind of interpolating, so is their any point aside from holding them still for the busbars after that?
for mine I use them in a mobile application (rv) so yeas I want to hold them together but I also have them clamped so the busbars don't get excessive movement when charging and discharging. All I did is put the little Seperator sheets in-between the cells for a little protection and clamped them between two aluminum plates till they were snug, I would guess around 15 inch lbs in 3 years my original 280AH has never had a bus bar loosen up or anything so its doing the purpose I am using it for.
TL;DR, but it isn't gas expansion either.
The anode, cathode, and electrolyte all change density (and thus volume) as the charge and discharge reactions occur. The lithium ions move from one side to the other and back during a cycle. I'm pretty sure that these volume changes are what drive the internal pressure. Allowing the walls to flex increases the odds of an internal short as tendrils form or the anode and cathode shift towards each other.
Keep in mind also that when this thread started the advice from EVE was to add more than about 8 PSI but less than about 18 PSI (from memory, so nobody beat me up if I'm off a little) on the flat faces of the cells.
The advice these days seems to be to apply about 12 PSI and don't worry about the upper limit. This would tend to negate the use of springs or foam and just use a hard fixture. If I were building my batteries today, that is very likely what I would do.
I've read some of this topic thread, can people confirm to me what the recommended clamping force should be for a 280ah cell in Nm & do you multiply this by 4 cells for a 12v battery pack?
Nm being applied with a small 'bicycle tool' 1/4" drive torque wrench, clamped between 2 suitable metal plates with suitable studding.
Thanks
No. The pressure will not compound but will be equivalently distributed across all members of the assembly. They will each experience the mfg’s intended parameters.
You mean that each will experience the same compression force. The intended parameters have nothing to do with the actual force applied.
@obd.tech, using torque on a bolt to apply a specified force is a notoriously pesky way to achieve a known force. The primary factors are surface roughness of the threads on the nut and bolt, the amount of lubrication applied to the threads, and the pitch of the thread selected for the job. If I were planning to do it that way, I would build a test jig and carefully measure the force applied by the fasteners over a range of torques and use that information to estimate the needed torque.
No. I meant that if one was configuring to achieve the manufacturer’s recommended compression force- intended parameters- and did so, the resulting force applied would be the same across each in the series of cells. I assumed a bit of inference would be applied 😀
Thanks
My fixture is using 2 yellow pine pieces of wood 1 inch x 10 inch cut to length with 4 holes drilled in each piece (2 top 2 bottom holes). Four 1/4 inch course threaded rods with 1/4 inch nuts & washers are used through the holes of the wood on each end of the 8s Lifepo4 battery banks and snug the nuts down.
This is Info I used and torqued a little less at 5 Inch Pounds with a torque wrench at about 3.2 to 3.3 volts charge in each cell. The cells are essentially just held in place.
The spec from EVE was 300 KG force which rounds off to 660lbs. Battery face is approx 6.85"x 7.874" = 53.94 sq inches
660lbs/53.94sqin=12.23 lbs per sq inch
Divide 660 by 4 bolts that's 165 lbs Axial (clamping) force per bolt.
Using 4 course 1/4 in threaded rods that should equate to roughly 8 INCH pounds torque per bolt. Realistically, that's a snug twist of the wrist on a regular nut driver for the average build mechanic.
So how do you measure the clamping force applied? To work out the stud
Only problem is a tiny bit more oil or even rougher threads on one of the pieces of all thread or nut and all bets are off on where you are compression wise.
Rig up a test with two blocks of wood that straddle a bathroom scale. Put a hole in each end of each block and you can test out the torque for just two lengths of 1/4-20 all thread, nuts and washers. A dry run will know if the math is correct for your hardware. 330lbs for two? Also, if I were you I’d probably error on the lower side of compression for WHEN the cells try to expand. Who knows what kind of pressure it’ll see. A 3/4” thick pine end plate will bow with time. I suggest to double it or use a couple of aluminum angles 1/8x1x1 at each end that the studs go through to backup the plywood. If you must remove the cells from the fixture after use, only do so when cool, a lower state of charge and re-fixture within an hour or so. Don’t let them relax too much. I use springs in my fixtures but there’s plenty of people that have rigid. Haven’t heard anything bad one way or the other which is best so I’m not judging anyone.
That’s a concern with moving, mechanical things like bearings or a pressurized vessel of some sort.
It would seem to me that battery compression fixtures to a manufacturer’s specification or recommendations is less about the exacting torque of fasteners and resulting clamping force and more about creating a containment mechanism from everything I’ve read or seen.
One shouldn’t position themselves to drown in the details when the details are only one inch deep. In other words, one shouldn’t overthink the details if one is debating with a talking sparrow.
The idea is mere containment - and think of how many manufactured batteries are essentially not compressed at all!
I find it interesting that we are almost 1,000 posts deep in this thread and still debating whether compression is needed.
You mention pressurized vessels needing proper pressure, then say that you just want containment for batteries. The EVE specification is pressure. That part is stated very clearly.
