Looking to build a 12v 400w system with a 40A mppt charge controller similar to Will's recent egg crate system. I'm planning on starting with a 200 watt solar panel and later adding an additional 200w panel so that my system will eventually be 400 watts. I want to go ahead and size all the wiring and everything now so that it will be able to handle the bigger solar array down the road and I won't need to switch anything out and can just add the second 200w panel in parallel. I see where 10 AWG wire is rated for 30 amps, so I'm confused as to whether I should go ahead and use 8 AWG wire for the charge controller and battery connections to the fuse box, and 10 AWG for the DC appliance connections?
