I have a 100Ah (1200 watt hours) 12-volt battery and a 100W 12-volt panel, and here is what I came up with:
At full sunlight it would be delivering around 5-6 amps or (50-60 watts) to the battery.
I know I shouldn't go below 12.2 volts - 50% of the capacity.
Where I run into problems is with my understanding of the charging time and storage capacity relationship.
I hope this makes sense... How can I calculate the charging time from 50%? If I am generating 5A (60 watts) from the panel, (omitting losses), how can I calculate charging time?
Also, Will talks about how important it is to not exceed the rated output of a charge controller, but aren't the input values important, too? I would think it would be a problem to have 5 panels and 35 amps going into a 30A controller, right?
