Routemaster
I see somewhere that one should not connect up six batteries up in parallel could someone be so kind as to help me out to keep the 12v output? Very new to this subject.
Den.
Den.
To keep all things equal, I would carry on the connection in parallel add the two 100ah batteries into the mix of 4, 100ah batteries in same configuration for a total of six.I have bought 4 off Li Time 12v 100AH LiFePO4 Trolling Motor and then bought two more (2) later then I have a 4/0 welding cable connecting the four (4) at this time do I carry on the connection in parallel for the two or would I have to make two sets of three somehow?
Yes to Ted.To keep all things equal, I would carry on the connection in parallel add the two 100ah batteries into the mix of 4, 100ah batteries in same configuration for a total of six.
Do the Li time batteries have internal BMS?
There is one drawback of the parallel wiring.. And that is the reduction of capable current from the pack available to the load which can still cause a chain reaction of the bms all shutting down. If the load is never high enough to trip the remaining bms overcurrent protection then this doesnt happen.If putting battery packs in SERIES, there is a voltage increase issue and should one fail in such a configuration there can indeed be many unpleasantries.
When putting packs in Parallel, they are the same voltage across all packs, the only thing that changes is the stored capacity (AH) and if any pack fails within a parallel setup, it will not have a negative affect on the other packs. There are a LOT of us here running well over 4 packs in parallel.
There are also many people here who are using LiTime batteries as Will did reviews on them, including terardowns etc over the past couple of years.
How is that funny? Its a valid drawback unless the battery back is sized to output a much higher continuous amp output than the load ever reaches.There is one drawback of the parallel wiring.. And that is the reduction of capable current from the pack available to the load which can still cause a chain reaction of the bms all shutting down. If the load is never high enough to trip the remaining bms overcurrent protection then this doesnt happen.
If a 160A load is tripping the paralleled BMS of two 100A batteries, there is a wiring issue.There is one drawback of the parallel wiring.. And that is the reduction of capable current from the pack available to the load which can still cause a chain reaction of the bms all shutting down. If the load is never high enough to trip the remaining bms overcurrent protection then this doesnt happen.
Most likely yes, I agree. but some state otherwise to quote this companyIf a 160A load is tripping the paralleled BMS of two 100A batteries, there is a wiring issue.
If they recommend this, don’t be suprised if some headaches arise.I wrote to the company and the response was not to have more than four (4) batteries in parallel because of the damage to the BMS board.
these are lithium batteries so it does depend on the the batteries and bms used in the batteries as there is no baseline certified standard it seems. add to the fact that a applications and load vary from application to application.If wired properly I can't understand what the issue could be for parallel operation.
