HighDesertOffgrid
Solar Addict
- Sep 15, 2022
- 628
Probably not for a minute, but is it scaleable? Skip to 6:00 for spoiler.
10M cells to create 1kwh (napkin numbers).Not scalable to what you want, good for clocks or space probe.
Not sure how many you could pack in a conex. She never gives the actual dimensions. If they are a half inch Sq by 1/8 high. It would make a watt per cu ft. Have plenty of solder on hand.I'm waiting for the one that comes in a 20ft Conex box with terminals and outlets on the end.
Aaaannyy day now, right?
She is clever.?"The half-life of that company was somewhat shorter than expected."
This is gold.
Not sure what you mean by exponential curve. Are you talking about the power output drop over the half-life?The stuff works by radioactive decay, and exponential curve.
So residential sized units that were grid tied could be viable?It is always putting out full power
? facts!After PG&E gets through with time of use rates, you'll want to add lithium batteries.
Sorry, apparently nickel.If it is made from Plutonium, I'M IN!
Can it produce 1.21Jiggawatts?If it is made from Plutonium, I'M IN!
if it does Im going back and winning the 1 billion lotteryCan it produce 1.21Jiggawatts?
Don't do that, if you do I can't win the 3 billion!if it does Im going back and winning the 1 billion lottery
Dang it!! there we go with time travel paradoxes, I always get the wrong answer on those.Don't do that, if you do I can't win the 3 billion!
