justinm001
- Dec 18, 2022
- 1,534
My coach came with a 50dn alternator and the faceplate is kinda rusted but it clearly stated 270 amps. My understanding is the 50dn comes in 300a 12v or 270a 24v but it was obviously setup for only 12v. I hooked up a wakespeed ws500 and it also shows its 12v (auto selected 12v voltage). I've had a problem where the alternator would run for 10 minutes at 13ish amps charging my lithium then get a battery overvoltage error 13 and shutdown . I assumed it was just a bit higher than it should have been so I adjusted the voltage from 12v to a custom 13v system and tried it out. Well turns out it ended up spiking to just over 20v before frying my firefly 12v control panel and a thermostat.
Now I'm wondering how alternators are converted to a lower voltage and if its possible something triggered it to switch back to 24v, or if they just replaced the insides of the alternator with a 12v model and it's just defective.
I'm a bit at a loss on what I should do as I planned on using this 12v alternator for the 12v system and adding a 48v alternator in another spot.
