What is a 12V outlet? Cigarette lighter plugin receptacle?12v outlet
Will you use it as a portable battery or stationary? I looked into this awhile back was going to use this battery box and make my own.For my cpap machine
My present way in my motorhome is a group 27 deep cycle battery in a plastic battery box located in a storage compartment below my bedroom. I ran a red/black zip cord to a female receptacle under the bed. It is good for about 2 nights with my machine set on 13 with the humidifier running.Will you use it as a portable battery or stationary? I looked into this awhile back was going to use this battery box and make my own.
I do like I said above. I am just looking for an additional way to expand what I have.Have you considered recharging your group 27 battery with solar while boondocking?
To expand, you need to tie in a compatible battery.I do like I said above. I am just looking for an additional way to expand what I have.
Please read the original post, that is what I am interested in.To expand, you need to tie in a compatible battery.
To replace, you can change to a different setup.
I would build a 280Ah LFP and drop it in an ammo can with a pair of cigarette outlets, and maybe a USB outlet on a switch.
We have used li-ion battery that I assembled to run my wife's CPAP unit, 12v DC. I think running with the water warmer it only used about 140watt-hours per night. 12v, 20 amp hour li-ion or LiFePo4 would do fine, for one night use. Lead Acid, I would maybe go a little larger amp hours.For my cpap machine
Gotcha.Please read the original post, that is what I am interested in.
I picked up this same toolbox with similar goals.What I ended up doing is making my own. I bought a Weize 50ah Lithium battery, found an ammo/tool box that it would fit in and a 4 panel cigarette lighter outlet. I already had the fuse holder, wires and crimp connectors.
Battery off Ebay $219.99
panel off ebay $15.28
box from Harbor freight $12.95
total $248.22 not counting wire and supplies
The total weight is about 15 pounds
I cut the tray that came with the box to fit the battery so it would not slide around and a spot for the wires to fold into.
After my first try to close the lid I made a stand off to make the wires go into the cut out better.
Also the lid touches the positive and negative posts so I heated and dimpled the lid to clear.
I charged it to 13.3 on the gauge that came with the kit
I used it last night with my Resperonics System One set on 13 in with humidifier on 3
After a very good uninterrupted 9 hour sleep the volt meter read 12.8
This morning I hooked up my 300 w Dokio solar panel and had the battery charged back to 13.3 in about 2 hours.
I suspect the voltmeter with the ebay panel is not correct so this afternoon I am going to check the voltage with a multi meter then the next morning after use.
then again the next morning after use.
View attachment 97219View attachment 97220View attachment 97222View attachment 97223View attachment 97226View attachment 97227View attachment 97228
View attachment 97229 then again the next morning after use.
