chrisski
Solar Boondocker
- Aug 14, 2020
- 5,192
I have finished my crate build: Originally a Crate Build: 600 wh, 24 Volt, 300 Watt Inverter, and put a second battery pack to make 1200 wh Goal was to continuously supply 250 watts of power which could get recharged simultaneously by 600 watts of panels. I will call that a success with a test where I ran it for six hours at 220 watts.
Picture of the old 600 wh battery pack
The upgraded Battery pack now 1200 WH
Parts Include A Victron Phoenix 24/375 Converter, A Victron 75/15 SCC, A small Daly BMS 30 amp discharge and 15 amp Charge, Aili Shunt, 8 S 25 ah 24 volt battery pack with TopBand Cells, a 45 amp ANL fuse, and some other things.
Bulk Voltage is 27.5
Float Voltage is 26.7
24 Hour no load voltage the Batteries settle to is 26.7 volts.
In full transparency, I'm going to post my parts list, and links. Please note with this list, there are some tooling up costs included, but there is about a like amount of cost I was able to save by using on part items.
And One Final pic of it in use:
A pic of the on off switch I also have a single USB Charge Socket pair USB-C and USB QC3.0, NS added add two more dual port USB QC 3.0, and a pic of the cut off switch:
Total | $743.79 | |||
Two Batteries 24 Volt 280 ah Lithium Battery 280 ah cells | ||||
Date | Price | Item | Description | Notes |
7/28/2021 | $141.81 | 25 AH Cells | 25 ah Lithium Phosphate Prismatic cells Topband | https://batteryhookup.com/products/new-3-2v-25ah-lifepo4-topband-navitas-prismatic |
8/8/2021 | $21.27 | 30/15 Amp BMS | Daly 30 amp Discharge 15 amp Charge BMS | https://www.ebay.com/itm/333645598647?var=542740720261 |
8/18/2021 | $22.99 | 110 Copper Busbar | 110 Copper Busbar 1/8" X 3/4" X 2 Feet | https://www.ebay.com/itm/303841271273 |
8/18/2021 | $7.92 | -1/4 Threaded Rod -1/4" Pex A Pipe -M6 Nuts | -1/4 Threaded Rod 2 X 20" -1/4" Pex A Pipe White 5' -M6 X 1.0 Nuts 5 total |
Everbilt 1/4 in. - 20 tpi x 36 in. Zinc-Plated Threaded Rod 802217 - The Home DepotPerfect for anchor bolts, clamps, hangers and U-bolts and many more projects where a metal rod with continuous threading or no head or fashioned tip is required. Everbilt exclusively offers a variety of sizes, diameters and lengths to suit the individual needs of your job or project. These rods...
www.homedepot.com
Apollo 1/4 in. x 5 ft. White PEX-B Pipe APPW514 - The Home DepotApolloPEX is cross-linked polyethylene tubing designed for use within potable water piping systems. ApolloPEX Pipe provides superior durability, corrosion resistance and flexibility for the most demanding
www.homedepot.com
Everbilt 6 mm-1.0 Stainless-Steel Metric Hex Nut (2-Pieces) 00188 - The Home DepotThese hex nuts are internally threaded and have a hex drive for nearly all general applications. The most commonly used nut, hex nuts are used in any application with a mating male threaded machine bolt
www.homedepot.com
8/18/2021 | $5.79 | M6 Nuts | -M6 X 1.0 Nuts 30 total | https://www.homedepot.com/p/Everbil...Steel-Metric-Hex-Nut-2-Pieces-00188/202249552 |
8/18/2021 | $6.38 | Ring Terminal | 10 AWG 1/4" Ring terminal Pack | https://www.amazon.com/Elec-Connector-Waterproof-Automotive-Electrical/dp/B075MB7FW8/ |
8/21/2021 | $9.75 | Zinc Plate | Zinc for electroplating terminals | https://www.amazon.com/gp/product/B08XP6J9LQ |
8/22/2021 | $1.79 | Alligator Clip, Threaded Rod | Home Depot | |
8/23/2021 | $20.74 | 30% Vinegar | 30% Vinegar for Zinc Plating Busbars | Home Depot |
8/26/2021 | $131.88 | 375 VA Inverter | Victron 24/375 Phoenix Inverter 300 watts continuous | https://www.amazon.com/gp/product/B01MR1B3B2/ |
8/27/2029 | $3.56 | M6 Nuts | M6 Nuts for batteries. Two packs of 10. Total of 20. | Lowes |
8/27/2021 | $4.42 | Mason Jar | Sealable Mason Jar for tinning nickel | |
8/27/2021 | $10.84 | Nickel Strip | Nickel for tinning | https://www.amazon.com/gp/product/B07KP3M4LP/ |
9/3/2021 | $77.23 | Bus Bar / Monitor | 100 amp 4 Stud Blue Sea Busbar #10; Ali Battery Monitor | https://www.amazon.com/gp/product/B000OTJ8A0/ https://www.amazon.com/gp/product/B07CTKYFTG/ |
9/1/2021 | $8.84 | Hardware For Crate | 2 each 8' 2"X1" boards #8 1 1/2" Wood Screw 25 Pack #8 3/4" Wood Screw 35 Pack | Home Depot |
9/2/2021 | $8.96 | Hardware for Crate | 9' Board 1X2; 2 X Carrying Handles 2 X 1/2" Wood Screws 30 Packs 4 #6 2 1/2" Screws | Home Depot |
9/3/2021 | $10.84 | Spare Fuse | 40 amp ANL Spare Fuse | https://www.amazon.com/gp/product/B01LYQVTY3/ |
9/3/2021 | $62.79 | Lugs, Splices, Connector | 50 Amp Quick Disconect for Battery; Mixture of 4-8 AWG Lugs; Variety of Butt Splices |
9/4/2021 | $1.05 | BMS Holder | Popsicle Sticks to make BMS Holder out of | Walmart |
9/4/2021 | $9.66 | 8 AWG Wire | 8 AWG Wire for Battery and Inverter. 5' Each red and black. | Orielly |
9/5/2021 | $23.72 | Open End Crimpers | Crimpers for open end Rings for small wires 26 AWG. (Can't Verify these work; Didn't use this) | https://www.amazon.com/gp/product/B08J3SDJTX |
9/6/2021 | $6.38 | 14 AWG to #10 Ring Terminals | Ring Terminals for accessories for busbar. | Auto Zone |
9/7/2021 | $44.77 | 8 AWG Rire 14 AWG Wire | 8 AWG Wire -5 Foot Red -5 Foot Black 14 AWG Wire -50 Foot Red -50 Foot Black All THHN Wire | Home Depot |
9/8/2021 | $13.08 | Hardware | 1/4" to 16/14 Gauge Rings; Screws | Home Depot |
9/9/2021 | $10.80 | Anderson Power Pole Cover | 2 Position, Quantity of 20 | https://czh-labs.com/products/rubbe...s-pp15-30-45-anderson-powerpole-connector-379 |
9/9/2021 | $18.43 | Anderson Power Pole | 20 pair 45 amp for up to 12 gauge wire | https://www.amazon.com/gp/product/B07Y9DMGG6/ |
9/10/2021 | $24.48 | Combiner Box | Home Depot 4 X 4 X 2 Junction Box; 2 Sets of 4 position grounding bars | Home Depot |
9/14/2021 | $16.28 | On Off Switch | Non-UL Rated 250 amp on-off battery switch | https://www.amazon.com/gp/product/B08RRTDSFB/ |
9/16/2021 | $8.67 | 3/8" Terminal Boots | Red Color. Protect on/off Switch | https://www.amazon.com/gp/product/B07CCG4X9T |
9/18/2021 | $8.67 | 5/16" Terminal Boots | Black Color. Protect Shunt Terminals. | https://www.amazon.com/gp/product/B07CCJS4Z6/ |
